hát, szerintem a szonda kábelei/csatlakozóit is csekkolni kéne.
Valamint külön a szondát is ki kellene mérni működés közben.
Akksid rendben van?
süsnye18-10-2013 21:25:25 // 46237
Tom8518-10-2013 21:08:39 // 46236
Itt van a Log file:
"READING ERROR CODES:
1: 1C - Lambda sensor
The After-cat.converter Oxygen sensor signal indicated by the code is incorrect, out of range or missing. This O2 sensor monitors the residual Oxygen in the exhaust, after the HC, CO and NOx eliminating reactions, and enables the ECU verify both the converter and the pre-cat. O2 sensor functions. Depending on system, the sensors may be of the 0-5V or 0-1V type.
Usually, if the system is in good working order there is a small quantity of oxygen in the exhaust and the signal rarely reacts. Mostly, a signal reaction can be seen by e.g. snapping the accelerator quickly several times (strong enrichment).
Before replacing the sensor, check:
- Check the post-cat. O2 sensor signal behavior from the data parameters or with a Multimeter or Oscilloscope: enrich strongly the mixture with repeated throttle snaps
- the exhaust for excessive O2 with an exhaust analyzer
- the exhaust system for leaks between and near the O2 sensors and at the converter to exhaust joints
- Aux. Air system (if present) for leaks or excessive air supply.
The reason for this fault is Open circuit / Short circuit at ground
The current status of the fault is Impact occurred / Present
The error counter value is 54
2: 07 - Air flow meter
Mass or Volume Air Flow Circuit Malfunction
The reason for this fault is Unknown / No power supply
The error counter value is 55"
kispeterz18-10-2013 21:07:07 // 46235
Imádott 147-esem jobb hátsó részéből tompa kopogást hallok. Egyenletes haladásnál nem, de egyébként igen sűrűn, ill. ha felnyitott csomagtartónál lefelé nyomom a kocsit intenzíven hallatszik.
Van esetleg 5lete valakinek?
süsnye18-10-2013 21:05:46 // 46234
és milyen hibát dob pontosan?
Tom8518-10-2013 20:58:42 // 46233
Jaa, azt eddig nem írtad, hogy előtt! :) Egyébként előtte nem volt semmi észrevehető növekedés. Csak városban használom, így jó szondánál kb. 8-9 L volt (városon kívül kb. 7), most az utolsó 2 tanknál pedig 10-10,5.
GTPeti18-10-2013 20:50:29 // 46231
Én pedig ezért kérdeztem, hogy a szonda halála ELŐTT nem tapasztaltál-e magasabb fogyasztást... Ui. ha túl dús a keverék vmi okból, az okozhat idő előtti exitus-t.
Tom8518-10-2013 20:47:21 // 46230
Hát igen, szerintem sem, azért is kérdeztem meg itt a fórumon!
GTPeti18-10-2013 19:19:38 // 46229
A szonda nem romlik csak úgy el 10ekm alatt. Ezért kérdeztem.
Mr. Z18-10-2013 15:09:00 // 46227
Leszedett emblémát, mivel lehet visszaragasztani?
Tom8518-10-2013 08:46:52 // 46226
De, azért néztem rá laptoppal és derült ki, hogy nem jó a szonda! Kb. 1,5 L el nőtt a fogyasztás.
GTPeti17-10-2013 21:19:37 // 46225
A fogyasztáson nem venni észre, hogy valami nem OK?
Tom8517-10-2013 18:39:08 // 46224
Hát igen, arra gondoltam, hogy nem volt hibakód. Mondjuk, ha most törlöm a hibát, így, hogy tudom, hogy rossz az LMM, akkor utána nem is dob semmit. Kell neki pár nap mire újra dobja a hibát. De amikor beraktam az "újakat", akkor direkt ránéztem többször is pár nap/hét után és nem volt semmi hibakód.
süsnye17-10-2013 18:19:00 // 46223
az mit jelent, hogy a FES szerint nem volt gond velük?
Ha azt, hogy nincs hibakód, az még sajnos nem jelenti azt, hogy minden rendben van.
Nekem pl. hibás volt az AFM karakterisztikája, tehát nem volt teljesen rossz csak bizonyos tartományban. Ha a rossz AFM miatt rossz a keverékképzés, akkor idővel azt a lambda szonda megbánja.
Tom8517-10-2013 18:08:14 // 46222
Sziasztok! Szerintetek mitől lehet, h a gyári belevaló BOSCH lambdaszonda kb. 10.000 km alatt tönkrement? 1.6 TS-ről van szó. Ezelőtt próbálkoztam mással is mint a BOSCH, azt nagyon hamar gallyra vágta (azt hiszem NTK volt). Az igazsághoz hozzátartozik, h az LMM sem tökéletes a Fiatecuscan szerint, viszont menettulajdonságra nem lehet érezni, h rossz lenne. Szerintetek lehet összefüggés a "rossz" LMM és a tönkrement szonda között? Most már nem tudom mit csináljak, mert ez a 2. szondám (amit újként vettem) és a 2. LMM ami tönkremegy (igaz, hogy ezeket használtan vettem, de amikor beraktam a Fiatecuscan szerint sem volt gond velük).
Riki16-10-2013 17:07:07 // 46221
Köszi, reménykedtem azért, hogy belehet vhogy küzdeni bontás nélkül.
Ferke16-10-2013 16:32:22 // 46220
Na igen, merthogy a rugó is útban van ugye...az meg csak úgy rakosgatható kényelmesen ki-be, ha a gátló is lent van, de ugye ez mindössze 1 csavar, oldalanként...:)
Riki16-10-2013 12:00:14 // 46219
sziasztok! 146-nál a hátsó lengés csillapító porvédő ütközőit , mennyire nehézkes cserélni? ki kell hozzá venni a lengés csillapítót mindenképpen?
Liquid15-10-2013 20:40:39 // 46218
önmagához képest nem rossz, hiszen majd egy évet kibírt :) Sima izzóhoz képest nagyon rossz
Jata15-10-2013 20:06:04 // 46217
Nem kel help. Megtaláltam.
mgabor13-10-2013 10:08:31 // 46216
Veszprém környékén ajánlott, alfához értő villamosság szerelőt keresek.
Zoli8510-10-2013 16:53:42 // 46215
HAli!
Nekem Nyíregyházán kellene olyan aki ért az alfákhoz.
Köszi az infót.
Köszi az infót.
Ferke10-10-2013 14:35:36 // 46214
Wik verdájával pont ez van most, eddig úgy néz ki, hogy a gyertyakábelek lesznek a gyanúsítottak:)
Arno16610-10-2013 14:14:50 // 46213
Hölgyek Urak, lenne valakinek feleslegben egy 2.0TS régebbi ALU (tehát nem a műanyag) motorborítással bíró motorra való hibátlan szelepfedele? Enyém repedt, 20K racing meg csak szivárog szivárog, a megrendelt szelepfedél pedig nagyon lassan akar megérkezni (emberem külföldön), és meguntam a várakozást. Köszi előre is! (Egyúttal köszönöm a múltkori gömbfej javító műhely tippet)
GT Ɨ|ѯ10-10-2013 09:12:21 // 46212
Látom Bölcsek kövét vacsoráztál..:-)
Buksi10-10-2013 01:54:56 // 46211
Sztem annyira nem jó! :-/
Fairlane10-10-2013 00:36:45 // 46210
10 hónapot bírt ki a "GE Megalight Ultra +120% " csodaizzóm, ma kiégett az egyik.
Nem tudom eldönteni, hogy ez jó vagy rossz? :S
Csancsi09-10-2013 21:12:45 // 46209
sziasztok!
Segítséget szeretnék kérni . Az autóm melegen dadog és induláskor váltáskor rángat , alapjáraton van egy kis fordulatszám ingadozás. Hidegen tökéletes, hibát nem produkál.Ha valaki tud valami okosat írjon .
Köszönöm
Köszönöm
Jata09-10-2013 20:36:01 // 46208
Estét!
Helyzet a következő: Hol találom annak a csatinak a végét a kötegben ami a jobb első sárvédőben van a tankszellőztető szelepnél. Tehát azt a 2eres kábelt hol keressem a motortérben?
145 1.6 TS 2000 120Le
Otto09-10-2013 20:03:36 // 46207
Létezhet az, hogy ha el van rakva egy fogat a vezérlés 1.9jtd-n akkor az rendesen indul,van alapjárat felpörög, jön megy?
Szép is a hangja, álló helyben ha pörgetve van semmi rendellenességet nem produkál.
DE, menet közben már kis terhelés mellett is kopog, vagy zörög, vagy csetteg, nem tudom hogyan írjam és nem is megy rendesen és kormol.
Olyasmi a hangja mintha hidrótőkék zörögnének.
Arra gondolok, hogy nincs a vezérlés a helyén és elérheti a szelep ilyenkor a dugót, de azt terheletlenül is kellene csinálnia. Vagy?
GT Ɨ|ѯ09-10-2013 08:00:29 // 46206
biztos vagyok benne ha felhívod:-)
elég rugalmas a bemutatkozószövegük
6UR2009-10-2013 07:24:05 // 46205
Az volt az első, megvan húzva rendesen. Megyünk tovább :)
Fairlane08-10-2013 23:19:07 // 46204
Kösz. De ez ad el "alkatrészt" külön is?
Ferke08-10-2013 21:06:46 // 46203
Az lesz az, ja:)
DieselManiaco(NagyVad)08-10-2013 19:55:26 // 46202
de még fent is megnézném a toronyszilentet,meg a teleszkóp szár végén az anyát mert azt könnyű nem rendesen meghúzni...
6UR2008-10-2013 19:51:31 // 46201
vmi ilyesmin gondolkodom én is kb ez lesz :D remélem megtalálom.....
GT Ɨ|ѯ08-10-2013 19:35:37 // 46200
Elérhetőség: 1134 Budapest, Szabolcs u. 4.
Tel.: +36/30-921-8349
www.autokarpitozas.hu
www.bortisztitas-borapolas.hu
info@autokarpitozas.hu
Radics Márk
Radics Márk
Fairlane08-10-2013 19:23:04 // 46199
Azt tudja esetleg valaki, hogy az üléskárpitok szélére varrt "J" profilú műanyag szegélynek mi a rendes neve, és hol lehet ilyen kapni?
Piritu - 1.000.00008-10-2013 17:30:17 // 46198
Ja, és mind egyforma.
Piritu - 1.000.00008-10-2013 17:16:29 // 46197
DieselManiaco(NagyVad)08-10-2013 17:07:38 // 46196
van a zárófelületén egy kb 1mm-es furat,amin légtelenít. ha nóném nagyon ereszt akkor az valszeg nem fogja produkálni az üzemi hőfokot.
DieselManiaco(NagyVad)08-10-2013 17:03:12 // 46195
valami nem lett meghúzva,én aláfeküdnék egy marék kulccsal és mindenre megpróbálnék ráhúzni..
6UR2008-10-2013 16:39:08 // 46194
A stabilizátor csak pont azon azon az oldalon a másikon nem lett, a stabrúd szilent meg elvileg jó. A kipufogón gondolkodtam én is de megrángattam és épp csak nyöszögöt egy kicsit ami be se hallatszana az utastérbe+nem is arra az oldalra esik (itt elnézést kérek a hülyeségemért mert az autó jobb hátuljából jön a hang nem pedig balról amit először írtam) . De mentem úgy is h a párom vezette az autót és beültem jobb hátra egész biztos hogy onnan jön valahonnan de hogy honnan?......
Buddha08-10-2013 16:00:34 // 46193
Rakd rendbe hamar a bowdeneket és a kulisszát ahogy a kollegák leírták, mert én cseréltem már váltót is ilyen gond miatt. Ha sokat jársz vele így akkor megéghetnek a léptetővillák, mert nem tudnak alaphelyzetbe állni.
Tuningman08-10-2013 15:29:43 // 46192
Nincs más, tölts bele egy kis vizet.
Mindenképp zárnia kell.
gecsa08-10-2013 15:25:28 // 46191
esetleg még egy tipp, hogy a kipu nem ér el semmit?
gecsa08-10-2013 15:24:38 // 46190
stabilizátorok, meg a stabrúd szilentek is lettek cserélve?
6UR2008-10-2013 15:21:43 // 46189
Sziasztok. Az autó bal hátuljából halk, de határozott kopogás hallható. Az egész hátulja új lett (lengéscsillapító lengőkarok stb) és mikor elhoztam akkor még nem is kopogott hanem fokozatosan kezdett el kopogni. Szerelés előtt még nem kopogott most viszont már nem csak gödröknél hanem már kisebb huppliknál és ha arra az oldalra esik a terhelés kanyarban akkor is csinálgatja. Egyenes úton semmi. De nem számít a gödör nagysága ugyanolyat koppan kicsinél mint nagynál, mintha egy műanyag vödörben egy puha teniszlabda pattogna halkan :D Ettől jobban nem tudom leírni a hangját.
Ötlet ? :\
Előre is köszi.
Ötlet ? :\
Előre is köszi.
tzoli15508-10-2013 13:27:39 // 46188
Az aksi alatt a váltó tetején lévő kulissza szorul. Szedd szét, pucold meg, zsírozd át és hibátlan lesz.
