Pac28-03-2007 16:55:06 // 14965
Ja és garancia?
Pac28-03-2007 16:50:08 // 14964
Üdv Mindenkinek! Át tudom érezni a dolgot....:-( Én tavaly októberben jártam úgy, hogy kb. 1 óra alatt repedt be a szélvédő bal oldala cirka 30 centit... Ok: egy apró köfelverődés, de olyan helyen amit csak nagyítóval lehet látni. A gumi tömítés mellett 1 mikrométerre... Nekem csere volt. Szerintem a Tiéd vagy megfeszülhetett (rosszul rakták be) vagy neked is egy nagyon apró kőfelverődés :-( Nézted?
mesa28-03-2007 14:01:54 // 14963
OFF Water temperature display :. The water temp rises too slowly, hitting 90c° only after 10Km (driving about 90Km/h with 5c° outside), when temp reaches 90 it suddenly drops to 75-80 and then rises a little but usually is always below 90c°. Reason: Alfa uses a different way of showing the temperature compared to i.e. Opel, Audi, VW. I guess Seat is VW so...... The difference is that in fact the temperature always goes up and down because there is a thermostat (in all cars!!) that opens when the cooling circuit reaches a certain temperature like 90dgr. When the thermostat opens, a whole lot of relativaly "cold" cooling drops from 90 to 70-75dgr. Alfa shows this immediately on the temperature indicator whereas many other cars measure an AVERAGE temperature that goes up and down very slowly and certainly will not show the peaks like the Alfa way. I guess this is done because the "normal" car driver will get in panic and goes and see their dealer to check if nothing is wrong and Alfa is of the opinion that Alfisti, as real, true car drivers, as enthousiastic and knowledgeable car dirvers and can "see through" this. So, forget about bothering the dealer, just enjoy your Alfa and keep a regular eye on all engine fluids; don't forget the fuel tank ;-) Thanks to Gert-Jan from Holland for this info! alfa156.net
kertecs28-03-2007 12:44:21 // 14962
Amiket én hallok ismerősöktől... minden vasnak megvannak a nyűgjei Miután megvettem a 155-öt, fel-felvillant az injektor hibajelzőm, a srác bepróbálkozott a Stoll-nál (akkori pécsi márkaszervíz): hagyjam ott egy két napra. Na persze... Egyébként termosztát csere volt a megfejtés
csocsi28-03-2007 12:40:10 // 14961
Érdekes dolgok. Most lehet, hogy gonosz vagyok, de ezek szerint a német ipar kiválóságainak is vannak gondjaik :)) Mindenesetre tanulságos a történek.
kertecs28-03-2007 12:33:29 // 14960
Surcy28-03-2007 08:11:48 // 14959
Szaszto!Hasonló remek élmény?Novamberben cseréltettem szélvédőt.Vasárnap használtam a vasat semmi,hétfön pihent a garázsban,kedd délelött beülök a vasba kitekintek a szélvédön és egy jó 20-25 cm es REPEDÉS tekint vissza az anyós olbalon.Sikitó frászt kaptam.Gyorsan elmentem mgcsináltatni 5000-ért.De,hogy MITÖL lövésem sincs!
Kazes☻27-03-2007 23:00:15 // 14958
Önindító?
Kazes☻27-03-2007 22:58:57 // 14957
Nem sok minden változik,csak olykor-olykor, kisebb fejlesztések, ám ez a probléma az én '83-as Giuliettámmal is előfordult már. Ezek ilyenek. ! ? :-)))
LuckyMan27-03-2007 22:31:47 // 14956
LuckyMan27-03-2007 22:30:51 // 14955
Valszínü neked is a vm lesz rossz.A motorhőfok nekem is dettó ugyan ezt produkálja,de én vettem bele gyári termosztátot egy vagyonért és semmi sem változott.Ezek a motorok egy kicsit tul vannak hűtve és azért nem megy fel a hőfok.Ha egy kicsit hajtom a vasat már mindjárt helyreugrik.
Pac26-03-2007 23:01:59 // 14954
Hi! Csak azon elmélkedtem, hogy hátha így jobban megérné, de ha 400e-t elmegy a kicsike, akkor tényleg felesleges. Ja, azt gondoltam, hogy nem occsó mulaccság :-) Akkor vegyétek a motorcserét költői kérdésnek...:-) Thx!
Üvegtigris26-03-2007 19:59:53 // 14953
Igen, a kodolás még érdekes téma lesz!
csocsi26-03-2007 19:57:04 // 14952
Mike.-nak lett már csinálva, úgy tudom jól bírja neki.
andraska26-03-2007 19:53:42 // 14951
sziasztok!! van valakinek tapasztalat vezérlés modosito,jav.készletről???jo vagy felejtős!!irjatok
andraska26-03-2007 19:51:23 // 14950
ha bicskás a kulcs akkor rázos 40 papir hegyalja kft.4 nap és megvan +rá kell kodolni a kocsira az még 5 ropi ha megvan a kod kártya +riaszto kod!!!
uaz146ti (kispali kisebbik fia)26-03-2007 12:17:13 // 14949
üdv! tegnap történt egy kis baleset a kulcsommal, konkrétan úgy széttört mint a ropi.. Volt itt trélerezéstől elkezdve minden... Most állok neki valahogy kiműteni a kulcs másik felét, ha ehhez van valami ötlet azt szívesen venném + arra lennék kiváncsi, hogy új kulcsot hol tudok csináltatni, mennyibe fáj és mennyi idő míg elkészül. előre is thx.
Ferke26-03-2007 10:52:57 // 14948
LOL!:))) Mondjuk egy kpl. vadiúj motor berakása sok apró problémát csírájában ölne meg!:)))) Csak nem annyir olcsó!:))))
Marklar15525-03-2007 23:37:25 // 14947
Dunakeszi. http://fiat-nemet.uw.hu/
Pac25-03-2007 16:15:29 // 14946
Ok, köszi a szakértést! :-)
granturismo25-03-2007 16:05:56 // 14945
Motort majd 400ekm körül.:-)
granturismo25-03-2007 16:05:10 // 14944
Na azért a motorcsere az durva lenne. Még vezérműszíj csere, hosszbordásszíj meg annak a feszítője ami megnézendő. Meg a kuplung, a fékek. Szűrők, olajcsere fékfolyadék fagyálló ellenőrzés ilyesmi, de motort azt ne:-)
Alfi_14525-03-2007 15:13:59 // 14943
Sziasztok!Valaki tudna nekem segíteni?Szolnokon v. környékén(50-100 km-en belül)tud valaki egy jó Alfa szerelőt,aki jártas a TS motorokban?Dízelhangos problémám van nekem is,de nem tudni konkrétan,hogy mi okozza(hidegindítás után kb. 2 mp-ig dízeles,utána elhallgat,majd ahogy melegszik a motor újra előjön a dízel hang)!A termosztátom sem tökéletes(üzemi hőfok kb.75 fok),de ha nem megyek az autóval,járó motornál álló helyzetben felmegy a hőfok 90 fokra,és elhallgat a dízel "ördög"!Van valakinek valami ötlete a megoldásra?
Pac25-03-2007 14:49:55 // 14942
Ok! :-)
csocsi25-03-2007 14:45:17 // 14941
Hát azért motrot ne cserélj :))
Pac25-03-2007 14:44:06 // 14940
Sziasztok! A véleményeteket és a tanácsotokat szeretném kérni: TS motor 200 e-s szervízénél (az általános: gyertya-, vez. módosító + görgők cseréjén, olaj, egyéb folyadékok és szűrők cserén) kívűl miket kell még átnézetni vagy cseréltetni? Vagy egyáltalán érdemes lenne a komplett motorcsere? (Bocs, ha hülyeséget kérdeztem). Előre is köszi!
mesa24-03-2007 21:06:32 // 14939
Szerintem jó helyre írtál! Nagy a valószínűsége.
andraska24-03-2007 20:57:50 // 14938
sziasztok!! nekem 2002. 156.1.6.ts van és most jelentkezik valami fura csörgö hang mit a hidrotőke remélem nem az.!!! hogyan lehet megtudni mi szol a motorban??csak inditáskor csinálja!!
Tocsa24-03-2007 13:04:51 // 14937
GOLDEN LODGE Forever !!!!!!!! :)
Piritu - 1.000.00024-03-2007 12:35:55 // 14936
Szerintem nem. Nekem ami be lett téve "örök" volt, később már nem kellett kicserélni, pedig a 146-al vagy 140ezret mentem vele utána. A hang úgyis jelzi ha gondolkodni kell a cserén. Amúgy ha elkezd kerepelni, akkor is simán lehet még vele menni, baj nem lehet, "csak" csúnya a hangja. Egyre inkább azt hiszem, hogy az olajon múlik minden nem a használaton. Szerintem a gyárilag berakott elsők azért szállnak el, mert a gyár a "bejáratáshoz" valami más olajat tesz be. Nem véletlenül ajánlják, hogy 5ezernél cseréld le.
isa15624-03-2007 09:14:57 // 14935
A 99 es 2.0 TS ben 80 e nél lett cserélve, azóta 60 e-t mentem vele, amiben rengeteg 1-2 km es városi használat van Eddíg még jól bírja. Nemsokára viszem vezérmű felújításra. Nem tudom érdemes e hozzá nyúlni.
Nasty23-03-2007 17:20:33 // 14934
Alsó lengőkar cserét tervezek holnapra. Van vmi különleges instrukció vagy értelemszerű az egész? Nem akarok a cserért külön még pénzt kiadni.
Haro23-03-2007 10:48:44 // 14933
Minimum!!!!!!!!!!!!!
kertecs23-03-2007 10:46:43 // 14932
Hiszen leginkább erről szól a 60E km-s szervíz ezeknél motoroknál. Nem? : )
Haro23-03-2007 10:42:22 // 14931
Bocsi nem neked akartam irni!!!:)
Üvegtigris23-03-2007 10:41:48 // 14930
Tudom, hogy jócskán több, ezért írtam... : )
Haro23-03-2007 10:38:46 // 14929
A vezürmüszijjat és a görgöket mindenképp cseréld!!!
kertecs23-03-2007 10:38:23 // 14928
Maga a szíj? : )
Haro23-03-2007 10:38:01 // 14927
Jócskán több:))))
Üvegtigris23-03-2007 10:35:58 // 14926
A szíj+feszítő+munkadíj szerintem egy kicsit több 5-8 e Ft-nál, vagy nem? : )
kertecs23-03-2007 09:56:27 // 14925
Hali! A vez.szíj csere mindenképp, de nem is ez drága részlet az egészben, kb 5-8E Ft. A hosszbordás szíjra gondolnak szerintem(ami a generátort, kormányszervót, klímát hajtja) , aminek állapotától függhet a csere.
Stef23-03-2007 07:51:18 // 14924
Köszi Haro! Vezérműszij állapotát lehet elenőrizni, vagy azt mindenképp érdemes cserélni, és ha kijön csak akkor látni, hogy jó volt-e még? (ez most kicsit zavaros volt)...
Haro22-03-2007 22:59:22 // 14923
Ha alkatrész kell olcsobban szólj!!!
Stef22-03-2007 22:14:15 // 14922
Kösz mindenkinek. Holnap megkérdem Szamosi mestert is, ha 100 körül kijön, inkább odaviszem...
Liquid22-03-2007 21:36:59 // 14921
Keress egy megbízható szerelőt, aki látott már TS motort, és van célszerszáma. 100-ból bőven ki fog jönni.
Üvegtigris22-03-2007 20:24:07 // 14920
Ha van független szervíz, amelyben bízol, akkor érdemesebb odavinni /gazdaságosabb és még lehet, hogy jobban oda is figyelnek rá, ha van ismerős, stb.../, de ha nem vág földhöz az a 30000 többlet , akkor vidd a márkaszervízbe.
Piritu - 1.000.00022-03-2007 20:16:58 // 14919
Bizony volt kerepelés, úgyhogy gariban csere lett belőle. Mind a három TS-emben cserélve lett a cucc. Viszont, amit a 146-ba tettek utána vagy 140e km-en működött. Szóval eddig amit betettek, már nem szorult cserére.
Haro22-03-2007 18:22:40 // 14918
Szerintem böven kijönn 100-ből de akkor minden pöpec!
Stef22-03-2007 18:20:51 // 14917
Tehát nagyjából 90-100-ból kijön? Egyébként amit munkaként leirtak, az megegyezik a szervizkönyvben leirt 60k-s szervizzel, csak kicsit (?!) sokalltam az árát. Volt mostanában valaki szakszervizben 60k-s karbantartáson? Szamosiéknál mennyi lehet? (Holnap fel is hivom)...
Haro22-03-2007 18:14:25 // 14916
Hali!!! Ennyiért nehogy megcsináltasd!!!! Ha kell tudok jó szerelöket ajánlani!
